Today my Reaction went up for flight # 5 & 6, I was trying to do 3 flights but, on the TO run for flight #7, the engine was not developing max rpms and I aborted the TO early ( you could tell it was not accelerating fast enough )
When checking with the gsu I found out it was not passing 90K at max rpms and the fuel pump was only at 1.1v out of the 2.5v is supposed to be doing, then I found the starter O ring is worn out, I have to change that first before I do anything else.
Other than that, the Reaction flew solid and awesome slow landings.
