RCU Forums - View Single Post - 1/6 F-105 Build Thread
Old 02-25-2019, 08:25 PM
  #378
invertmast
My Feedback: (23)
invertmast's Avatar
Originally Posted by Pull Up Now!
I think you're being a bit hard on Bob Moore. Smooth as a baby's bum is just an expression, it's not a guarantee. What Bob produces isn't a complete kit in the same sense as what a huge company with China production might ship. And even then, there are huge defects with those big companies. FEJ had a honeycomb structure problem for a while. Their gears misplaced an o-ring groove, causing the strut to have a paper thin aluminum section which can break with even a normal landing. Airworld has a landing gear without any positive downlock causing the gear to collapse. They produce hundreds of these kits, and have every opportunity to amortize the cost of fixing defects as they go, yet many don't. Bob Moore's talent is undeniable, just check out his threads on the 16 ft Cessna Citation nearing completion. But it's not realistic, when only 5 are produced, to expect it to go together seamlessly. You're buying a very limited run, custom shell that YOU have to finish. You will be the only one of those at an event, almost guaranteed. Also, you have no idea the work it takes to make those molds, and the cost of the resin and materials that goes into the molds even before he starts to lay up the actual flight airframe. THAT'S why it costs so much. Besides, it costs $4000-$8000 usually for a jet half the size of that F105. So please ease up on Bob Moore. Believe me you are getting what you paid for.
your right.
but that doesnt excuse the fact of simple things like balsa hinge blocks not even touching both skins. Of EVERYTHING involved in doing one of these projects, that is literally the simplist task involved.
