Originally Posted by
Jgwright
Edgar
The valve I used was the M5 1 way valve and I unscrewed the fittings and replaced them with M5 Festo ones. Simply tee off the lines for sending the Hydraulic to each retract in the usual way. The Festo ones I used were the smooth ones that have an internal Hex to use for screwing down. This will do the trick for both the nose and mains legs. You can vary the speed of the retract by using the speed controller but in practice I found that a small 2 cell Lipo was fine for power. They now do both brushless or brushed so the choice is yours. With the retracts I used M3 to 4mm pipe Festo fittings where space was a bit tight. The retracts will need to be taken apart to drill and tap them for the Festos and make sure they are clean of any swarf.
John
Have you found any pneumatic cylinders that wont work with hydraulics? Thanks for this info.
