I also decided to use a nylon nose gear block. I split it in half to get as large a spacing as possible. I also mounted that former at a slight angle so as not to need to bend the wire. I to plan on pull pull for the rudder and am undecided whether to use dual pushrods for the elevators. One on each elevator that exit outside the fuselage like a normal sport plane.
