Originally Posted by
JREEVES
Do you remember what size bolts and nuts you used? Your Abrams looks awesome!
The Abrams shown has 2x18mm screws and lock nuts. They can be
tight to fit as the HL metal arms are not super consistent from batch to batch. I have used slightly smaller and slightly larger diameter screws/nuts when building sets of these arms and wheels for others. I would recommend starting off with 2mm and determining the need for change from there, but whatever the size keep all the screws and nuts the same measurements.
