Os 120ax
Hi guys. I'm having a problem with my engine. When I got it, it was all gummed up so I decided to tear it apart and clean everything out. Problem is, I cant get the piston off the crank. Is there a procedure to do this? I have the piston top dead center and according to others, it should slide right off, but it hangs up about half way. Any suggestions? Oh, and yes I took the sleeve out. Oh, and also, I'm not sure where the dot on the sleeve goes? Any help would be appreciated. Thanks.
