RCU Forums - View Single Post - Xicoy - LG15 Gyro Controlled Brakes
Old 03-18-2019, 06:13 PM
  #74
Tip22v
Here are my settings for my T1 with Electron Wheels/Brakes:
Gryo Gain: -50%
Steering Mix: -60%
Gyro Mix: 60%
I use Heading Hold
i recommend trying to get the brakes as even as possible using the individual brake force adjustment before setting up the gyro, this will adjust out any significant differences in the physical braking differential before allowing the gyro to fine tune the rest.
These numbers should get you in the ball park. Of course, you may need to reverse the polarity of any of mine based as you radio and setup may be different.
