Scale appearance is a 3" thick root next to the body. HUGE leading edge air inlets to the engines...….. It is to be a sport plane. Stability when inverted would be nice. I will fly it as a bomber. Can I use a symmetrical airfoil for the main portion of the wing ? & a more stall resistant washout airfoil on the outer 3" of the wing for better stall resistance ? Like a Clark Y if I can find the pattern.
4 S F of wing area. The 2 wing panels are 8 oz. body will be about 3 oz. single tail pusher prop.
I do not mind having to use more power for the thick wing section. Please see if the scale wing shapes below are O K. Do I need any of the reflex curvature ?
Thank you.
