Originally Posted by
BarracudaHockey
Something needs to be clarified here.
1. IGyro is not true heading hold its a hybrid of rate mode and heading hold. When a stick is centered, lets use elevator for example, heading hold is engaged, but move the elevator off the center and heading hold is released and the gyro switches to rate mode until its centered.
That is NOT how most gyros implement heading hold, its either on or in rate mode and most commonly used to torque roll and then then turned off to fly. The feeling of flying in heading hold is very un-natural and you can get yourself in trouble. It's hard to put in to words the way it affects a plane in the air but think of taking off a prop plane, you're in the habit of holding some rudder, well do that with a heading hold gyro and it will keep turning harder and harder till you spin out and hit something.
That seems to make a little more sense. I was more curious about using the heading hold feature to hold a knife edge without the coupling that sometimes occurs. Thank you guys for the input
Tone
