Yes, guessed that’s how the skins would be laid up. But what weight cloth, single thickness on the outer skin? You going to carbon tape over the structure, you can reduce the structure considerably.
i would lay the wing with a thinner total sheet at the surface and a second layer from the root to just outside the flap pocket
