Originally Posted by
speedracerntrixie
Vincent, you don’t need me to keep you honest, you do fine without me. I do have something for you to think about though. Have you considered adding some right thrust? Going with a larger engine that will produce more torque, I would consider right thrust would be quite helpful.
I did think about adding right thrust, then decided that I would try flying it without without. I can add a washer behind the left hand side of the engine if need be...
