RCU Forums - View Single Post - Which rate do you normally sport fly on
Old 04-12-2019, 05:17 AM
jaka
Hi!
You should always use as much servo trow (100 % or more) as you can! That means using the shortest servo arm as possible and longest elevator /aileron arm as possible. You should never ever use dual rates with as low as 25%-50% travel...it's OK on throttle but not on any flying surface.
