Originally Posted by
1QwkSport2.5r
The initial settings are too rich for most people. Leaning the bottom so it will idle on its own but load up if left to idle for 15-20 seconds is fine. Preheat to 200F, prime and start the engine and drive it. After a half twnknor so, the mixture should be close to stabilizing. If idle is high and won’t drop down, reduce idle gap a little bit at a time. Each change narrowed to the idle gap leans the low speed a tiny bit. Repeat as necessary.
Thanks for the fast response. Leaning the bottom end. You mean to lean out with the low speed needle? This would allow it to idle without trying to drive off? The extra heat is to try and keep it running under its own power without shutting off?
