On a lot of my planes I use a piece of kevlar cord (or similar) to open the throttle and let the spring on the carb close it.
Works very well. There is MINIMAL resistance leaving the spring on the arm.
If you do decide to remove the spring, just unhook it from the arm, but leave the spring in place. It helps to keep the throttle plate centered and stop vibration that causes wear on the throttle shaft.
