Originally Posted by
Laggger164
Also I am thinking about getting this ESC for the sensored motor, looks a liiiittle more legit than the other ones, maybe they actually care a little on quality control, but who knows:
https://bit.ly/2DpmJAf
What's your take on this?
Thanks for any and all suggestions!
More than likely, your linked OCDAY ESC is the same as the "blue 120A" ESCs floating around the interwebs for the past few years, but changed the amp spec to a more "realistic" value along with putting everything into a black case. If you search TSKY 120A ESC, you will find mixed reviews. As far as quality control goes, the "ABC" wires are labeled backwards, and have been from day one. Blue motor wire should be labeled "A", and the Orange motor wire should be labeled "C" if you are hooking up a sensored motor.
I would go with Hobbywing's Quicrun 10BL120 ESC for when a person wants a non boosting/turbo sensored ESC with a warranty....
https://www.hobbywingdirect.com/prod...=2139725987868
