All,
I purchased the Morris Mini intake mod for my Fg60r3 and while doing the install I noticed two things that did not make sense. First is that the intake tube, internal diameter is only 7mm versus the 8.5mm on the stock intake. Second is that the location of the carburetor to manifold set screw is about 8* from the stock part. (stock is bottom center) That causes the carb to set at an angle and the throttle linkage now hits the motor mount. I have sent an inquiry to Mr Morris last week, but no response.
What dimensions and set screw location did you guys find on your intake mods? I am thinking I got the wrong manifold....
TX Jeff
