Originally Posted by
Glowgeek
You mentioned that before. Is it an easy retrofit like the 100 carb was?
well the 125 ID is .008 larger than the 100's,,
here's the 3 ID numbers,,,
82) .315,,
100) .336,,
125) 344,,
but keep in mind that I found the ventures ID's are not totally round, they are slightly oval.
and remember that the 125's Manifold has a larger OD than the 100 and 82..
but, I just found today that the Barrels on all 3 Carbs are interchangeable, so you could put a 125 Barrel in the 100 or 82 Carb, and open up the Carb's Intake venture, I wonder how that would work
boy these Saitos are very interesting engines, the wonders just don't stop with them
Jim
