RCU Forums - View Single Post - Aviation Design F16 Conformal Fuel Tanks
Old 05-16-2019, 12:12 PM
Typhoon Phil
Originally Posted by FalconWings
Really cool work. You should consider making these for the other popular F-16 scales.
BTW, if you bond these properly, you can cut the fuselage section and easily triple the engine bay volume.....lots of room for more fuel or smoke oil right at the CG!!
David
David yes have thought of that but only problem is that to get a proper fit to the fuselage, I mold the bottom surface from the actual models fuselage upper surface so would need to get my hands various actual models..... but if any one wants a set doing then no probs if I can borrow their model to fo it!!
