Old 05-27-2019, 08:22 AM
wcmorrison
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the equivalent engine in the Magnum. It is the same engine and parts are directly interchangeable. The engine did not come with any tools. The valve settings are the same for virtually all small four cycle engines. The clearances, cold (room temperature) are 0.04mm to 0.10mm. Break in prop recommend is 9 X 5, and recommended prop sizes range from 9 X 5 to 11 X 4. The instructions say you must have some Castor oil in the fuel mix for break in (and I never ever do not use some Castor in my fuel regardless of what engine I am flying). My engine is new in the box and I got it direct from Bandilear (no longer in business).
wcmorrison is offline
