Overall looking good. What is the reasoning behind the offset of -8 for the elevator input? Trying to get the surface centered?
You noted my use of "INV" on outputs for servo reversing previously. As you have done on elevator, you can change the weight from +100 to -100 for the same effect. I like to do it in outputs, for cases where I have two servos being driven by the same source, but one has to be reversed to move the surface correctly. Some setups can get messy trying to do the reversing for one of a two servo config via Inputs or Mixing, but other than that, there is no strong argument for doing it either way.
It looks like you are experimenting with logical switches, also. If you'd like, I'll share my use of those for an engine kill function.
