Originally Posted by
FlyerInOKC
I am going to change up things a bit with this quiz. I am looking for an airplane.
1. This aircraft was built by the producer of a famous fighter.
2. The subject aircraft was designed after the war the fighter served in.
3. The subject aircraft was designed in such away it could be sold to civilians as well as be attractive for military use.
Why, oh why do I do these things? I just can't resist these early long shot guesses. I'm guessing you're talking about one of the early post-World War I planes manufactured by Anthony Fokker. Maybe the C.I, C.II, C.III and/or C.IV. I'm kind of hoping I'm wrong here, but it does match up with the clues thus far. Thanks; Ernie P.
Answer: Fokker C.I, C.II, C.III and C.IV
The Fokker C.IV was a 1920s Dutch two-seat reconnaissance aircraft designed and built by Fokker. Design and development
The C.IV was developed from the earlier C.I but it was a larger and more robust aircraft. The C.IV was designed as a reconnaissance biplane with a fixed tailwheel landing gear and was originally powered by the Napier Lion piston engine. It had a wider fuselage and wider track of the cross-axle landing gear than the C.I. Operational history
Examples of the C.IV were delivered to both the Dutch Army Air Corps (30 aircraft) and the Dutch East Indies Army (10 aircraft). It was also exported; the USSR bought 55 aircraft and the United States Army Air Service acquired eight. Twenty aircraft were licensed built in Spain by the Talleres Loring company for the Spanish Army's Aeronáutica Militar. After service as reconnaissance machines the aircraft were then operated as trainers into the 1930s. The last flying example of a C.IV is a C.IVa with a Rolls-Royce Eagle VIII engine, preserved at the Owls Head Transportation Museum in Owls Head, Maine. It was used in a trans-Pacific attempt in the late 1920s or early 1930s. Pilots Bob Wark and Eddie Brown took out the seats in the passenger compartment and installed a large fuel tank. They also put a small cockpit just in front of the vertical stabilizer with a hand-powered fuel pump inside. In flight, the crew member sitting there would transfer fuel to the main tank in the wing, where it would be fed by gravity into the engine. In this trans-Pacific attempt they planned not to go straight across the Pacific but up the West Coast of North America to Alaska and down the chain of Aleutian Islands, proceeding down the Chinese coast to Tokyo. They took off from Tacoma, Washington and started to head north, but made it only about 100 miles of the way to Vancouver, British Columbia when the engine vapor locked and forced a landing in a field. They had to dump most of their fuel to bring down the weight in order to take off from the field. When they got back in the air, they started heading for nearby Ladner Field, Vancouver to top off the tanks, but they crashed upon landing and decided to give up. They loaded the C.IV onto a Ford AA flatbed truck and brought it back to Washington State. It ended up in Ephrata, Washington, where it was kept outdoors and was eventually badly burned in a grass fire. It sat until 1970, when one of the museum's trustees found it and restored it and donated it to the museum. It flies to this very day.
