So far I have the fuse assembled, doing the sanding on it, and got the cowl assembled and glassed inside. I found that Polyester resin has a very short shelf life and will not cure unless a LOT of hardener is added, so had to strip out all I had applied and used epoxy resin instead. Only reason I went the poly route was it usually cures quickly, when it cures. I have some pics, but they keep coming up corrupted when I try to load them from FB, so have to find an alternate way to upload them without connecting the phone to the PC first.
