This is my “orientation jig.” Once I cover the dome with Kevlar all firewall orientation will be lost. So I drilled two small holes on the vertical axis of the plywood disk for locating pins to engage. The arm they are on is mounted with removable countersink screws. The paper pattern will be transferred to the base of the mold when it’s done
so I know where to cut.
