Originally Posted by
ravill
The tanks came with tygon. I don’t like to use tygon inside tanks as it gets stiff very quickly. I’ll use BV’s in tank fuel tubing.
I was also told that the main dubro tires will roll right off and that I should switch them over to harder Robart tires. I was a little skeptical, but by just tugging on the tires I could see that they can easily come off.
Hi, Im changing my tank lines to Viton (purchased at McMaster). On the wheels I was advised that once you glue them to the rim it will work ok.
