RCU Forums - View Single Post - TF Beechcraft Bonanza F33A Build
Old 07-19-2019, 04:51 AM
  #120
VincentJ
VincentJ's Avatar
All of the ribs are installed plumb (90 degrees) except for the first rib (W2) which is set at 84 degrees to accommodate the wing's dihedral.
With the rocket tube in place, a small fillet of epoxy on each side of the rib was applied to permanently secure the tube.
The square aluminum stock on top of the wing was placed directly over the top wing spar which was glued into place. This will ensure the spar is making full contact with the webbing beneath.
The rocket tubes aren't long enough to span the length of the wing. To splice them together, I used a short length of 3/4" heat shrink tube.
