Originally Posted by
Tony Hallo
Looks like the bottom needs sheeted? Looks very good. How do you plan to finish the wings? I have 30% plans from Windal Hostetler that I may build some day, always liked the Beech, I had a Sig Bonanza back in the day, .60 Como engine, Carl Goldberg retracts, painted white and blue.
That's a big bird Tony... You are correct, the bottom hasn't been sheeted as of yet. I'll build the left wing panel next getting to the same point of construction as the right panel before I flip them both over and install the rest of the wood bits and retracts. The center section also has to be built so the wing halves can be joined together before I finish the bottom sheeting.
