Routed wires/air hoses to center of wing and put Y extensions on ailerons and flaps and T's on air hoses.
Landing light on left, underside of wing.
Using BVM's high intensity LED landing lights.
Comes with Y wire extension where one part of Y connects to receiver and other to battery source.
Each part of the Y has a sealed circuit board for controlling the light.
With LED's will probably go with receiver power.
Put another Y harness into the gear so one side goes to gear valves and other to landing light.
The front metal cover comes off and I cut it down so it's not such a large opening.
A dubro heavy duty hinge was used to secure light to ply hatch via wood screws and to light via drilling/tapping for machine screws.
Had to make hole in hatch large enough for back of light to clear in the raised position.
Assembly removable for easy PM.
Some lite ply epoxied to hatch cover to hold small servo. Still need to make a lite wire linkage between light and servo arm.
