Gear/door activation.
A Jomar electronic gear/door system is being used. One input wire connects to the receiver gear and two servos/valves are connected on the output side.
There are options for P-51/P-47 type doors and speed.
The yellow box is the Jomar device.
Gear test:
UP
Down.
Tail wheel.
Main gear door air cylinders. These are BVM's. They are just right for vertical mounting in the wheel well.
The tail wheel doors will be operated manually via a wire/spring connected the doors and across the tail strut.
