Presently, it was a dry tested to make sure all works. I had to move tubing around plus the Jomar has not been fastened down. The wires will be routed/secured and receiver is, also, not secured. The wires/hoses from fuse to wing will be tied together. Probably will use an easy connect for the wires.
