I highly doubt a hardware store will have diff shims. 8x16mm bearings are common on diffs on 1/8 scale platforms. I do believe Exceed uses them. So, 13.5 x 15.8 x .03 mm are, more than likely, the size shims you need. You will also find 13 x 16 x .X mm shims in different thicknesses.
