Old 09-03-2019, 12:36 PM
  #686
dusturbd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Chris Nicastro View Post
Dusturbd that elevator linkage you made is a good idea but I would be concerned with relying on that solder joint to take the torque load.
A better design would be to make the wire loop and twist so itís one continuous wire. Then solder a couple plates or a tube over the center section to box it in. This way is bullet proof and will not fail. Just a thought...
thanks for the idea
that is a silver solder joint I have used that same setup many times since the early 90ís and have never had 1 fail not to say it canít or wonít but I have had good luck with them
dusturbd is offline
