Old 09-03-2019, 10:24 PM
  #2695
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by mr_matt View Post
my version must be different, I have a threaded boss for the axle, it has to be a bolt I guess, with no way to lock it in.
Ok I have that version too. You need to find a shoulder bolt with a shoulder length similar too or slightly longer than the width of the your wheel hub. Then you just screw it into the leg with thread lock and itís done. The shoulder is your axle. You will need a spacer between the wheel and leg. The head of the bolt can be a hex cap or a pan head slot screw. In order to make mine look less like a giant screw I ground it to look like a grease cap with a shallow slot for a screw driver. See a P-51 wheel hub up close for a visual.
Chris Nicastro is offline
