need help with Dxe
My dxe transmitter will not bind to any rx, (even ones it has been bound to before) and whenever I turn it on, the leds flash for a second or two then go solid and at the same time gives two descending tones. then gives a tone that is repeated every second. also when it is buddy boxed with the dxe being the slave and another tx being the master the dxe only has right aileron, and pretty much no left same with rudder and elevator. whereas the master has full throw on all control surfaces.
