Old 09-16-2019, 06:09 PM
  #463
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Meanwhile, back at the workbench I got some work done on the nose gear door servos
Dry fitting the servo inline with the middle nose gear door hinge
I wanted it to be below the bottom of the cockpit tub cut out on the former so as not to interfere with anything later
I used the corner of the servo in the middle of the former hole precision line up method...
It looked good to me so how to make a mount with that curve on it?
I remembered my pink foam pattern for the former, curve close enough!
Traced former on file folder
I used a metal servo mount for a pattern
Final pattern after a little tracing and erasing
Pattern cut out and dry fit... looked good to me. The rest of the file folder became epoxy mixing cards!
I thought the F-105 was big...till I put the Havoc next to it! This bigger stuff has reached my limit! I need a crew chief to help move them around!
Viper1GJ is offline
