Old 09-22-2019, 05:40 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the expense involved in our models, my preference is to have multiple receivers. The risk you mitigate depends on factors that include how "clean" from a 2.4Ghz your field is, the location of your antennas in your install, etc
The deficiencies on taking advantage of the dual (or more) receivers mentioned above are not because there are more than 1 Rx, but rather the way the selection of signals is implemented in the Jeti systems. where there are multiple Rx.
Other equipment's will receive the signals from multiple Jeti receivers and select on "frame by frame" basis a valid signal. Using that approach, you can then receiver the full value of having multiple Rx's.
Edgar Perez is offline
