Main landing gear inner doors
I elected to use these metal offset hinges I got from Dreamworks. The hinge pins are held in by small set screws
Rough layout of gear door parts to see if locations will clear all the other parts
Servo below wheel is OK and hinges clear wheel in intake duct
HInge locations selected and marked
Inside edges marked for material removal to allow inside hinge half to fold under the outer skin
Small perma grit cutter used to rough out the hinge cutout
Permagrit flat file used to square the cut
Foam material removed under cut out to allow the inside hinge half to lay almost flat against the outer skin
HInges centered in the cut out
HInge alignment wire has to be at the outside edge of wing skin to allow door to swing over the curved surface
