Originally Posted by
PatternFlyer
I need some help locating at least a prop washer.
I couldn't pass on the deal on never ran (been mounted) Saito 45 MK III (no box or manual). It came with the Dubro 6x1.0mm aluminum prop nut which I hate. So, I gave it away to a senior club member who needed it for his Goldberg Cub. Then, I can't find a set of prop nut & washer for it. 😂
Anyone know where I can find one set. At least a washer is necessary. None of the current Saito uses 6mm shaft.
I am going to put it in the Kyosho Cessna 172 from early 80s this winter.
Anyone have a set laying around or know where I can get it, please let me know.
Thank you,
If it is 7 mm I may be able to fix you up. I'll report back.
