Saito FG11
Nrrd some help here. Saito FG11 ( small gas ) I can get it to run fine up to about 7000 rRPM then after that it cuts out. I can Turn the high speed needle out as much as I want and it doesnt affect how it runs at all. The factory recommended settings are 4/5 to 1 turn out on the high speed and 4 to 5 turns out on the low speed. I can turn the high speed out unti its almost out of the carb body and it still runs the same ( cuts out around 7200 RPM ) Engine is broken in, running 20 to1 mix with Klotz model oil Adjusted the valves running a 13X6 prop that is recommended, 6.6 life ignition battery,New spark plug. any thoughts?
