Originally Posted by
michaelr1
I use non ethanol gas . I am using a 3 line system and am sure the vent is clear. I will try turning the high speed needle in though. Thanks for the reply
Yes, if you haven't tried leaning the high speed needle that could very well be the issue. Factory recommended needle settings are only a starting point. Once you achieve peak rpm with the high speed needle you will need to adjust the low speed needle for reliable idle and a good transition when cracking open the throttle from idle.
Note: Watch your engine rpm when adjusting the hsn. Bring it to peak by leaning and then richen it a little (250 rpm down from peak) to keep the engine from overheating. Fine tuning gassers has to be done by flying them.
