Thank you the response. This is a photo of a Futaba servo plug on the left which works fine and the mini servo that's in the plane. The red is in the center on both and the negative is on the same side, just brown in color on the Parkzone plug. As already mentioned, the servo does twitch plugged in. I tried all the ports on the RX and the same thing. No movement.
