Originally Posted by
Zeeb
First thing to check is that you have the model in the same orientation as when you setup the AS3000. When you turn on the model with the AS3000 it takes longer to hook up with the tx, up to about 8 seconds IIRC. If that doesn't work, disconnect the AS3000 and see if everything works correctly.
Receiver Firmware is: SPEKTRUM AR20310T FORWARD PROGRAMMING VERSION 1.6.45 (APRIL 26, 2019)
Alright, you win, now tell me what the issue is!
Here's how it went:
1. As is, turned everything on, still no servo power (expected)
2. Disconnected AS3000
3. Turned Rx power back on - still nothing
4. Re-bind - then it all came on! Whoa! (everything works too)
5. Turned it back off
6. Plugged AS3000 in, turned it back on, nobody's home
7. Repeated steps 2-6 again without re-binding, same results
So is my AS3000 dead? Or maybe when I did the configuring it wasn't level (which I'm pretty sure it wasn't) and it's not letting the servos get power? If so, how do I get everything powered so I can get to Forward programming and re-calibrate it? And once there, do I just do the quick and simple system calibration or whatever it's called?
