Originally Posted by
TeamMuir1
in the video the guy disconnects the fuel line going to the motor.... I did just that
and performed the test. NO FUEL passed threw the Solenoid. I think thats
the problem. So if I had another solenoid I could change it out and put that theory
to the test. ONLY question I have are all the Solenoid's the same for JET CAT ?
I have 2 other motors I could change out the Solenoid's to test.
So your fuel solenoid is not working....I'm sure if you bypass that solenoid just for testing..the engine would start right up.
The main uses for that solenoid is to prevent fuel from leaking into the engine while you're fueling the plane...If you decide to try this test..close the manual fuel valve when fueling then open to start.
