Originally Posted by
TeamMuir1
I have another set of Solenoids and I tried what you said.. blowing threw the fuel line
while holding the button for the fuel purge and NO LUCK it does not open up the
solenoid.
I am only questioning the process... since its the same out come with another
set of Solenoids.
Well if your solenoid is good then it's the driver to the solenoid..ECU problem. Try bypassing it and see if it starts...;-)
