RCU Forums - View Single Post - Yellow Aircraft Stingray
Old 10-20-2019, 12:45 AM
  #59
Signofinfinity
Something of the sort... Using 1.5mm or 2mm Aluminium... Tabs to be bent to the fuse profile...
Originally Posted by mr_matt
I would abandon that mount and go to the tab and strap type. BVM makes them (it used to make them). As you suspected you want the thrust line much lower.
I ran maybe 1/8 inch reflex but I don't remember exactly how much. Your speed brake rigging looks perfect BTW.
FWIW
Thanks for that! I will Google some pictures of the BVM mounts...
I believe thrust line should be close to the longitudinal axis to avoid pitch moments ... Tell that to the 738Max, and our 320neos!😁😁😁
​​​​​​I will have to fabricate something to make it fit!
Thanks!
