Originally Posted by
john491
The problem seems to be that the GSU is not seeing the trim changes. Starts about 1118 ms and does not register any change from low to high idle, using the digital trim. The only change is the throttle stick itself- but that does not allow the learnrc to go to the next step.
John
Ok, so if you have a monitor function, can you see the trim moving the pipper on the throttle channel when you activate the trim?
