Old 10-20-2019, 07:44 AM
  #353
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm anxious for when Vincent gets to that stage. I personally use epoxy laminating resin and thin it down with alcohol. When the glass has been wetted out I go back with paper towel to remove as much resin as possible. A light sand with 220 grit then I smear light weight filler over the glass to fill the weave, sand again and then prime with Klass Kote white primer. I still have the issue of applying too much clear coat which is the step that adds the most weight.
speedracerntrixie is offline
