I sent Josh a couple of pictures showing the problem and my solution to the tailwheel assemblies deficiencies. The white control horn I'm bending was to be mounted with a small sheet metal screw, threaded into the plastic and set in a small dimple in the brass. I modified a Hitec servo arm, drilled and tapped the brass for a 2-56 socket head screw and set it. Now it's rock solid. I was going to make a charging hatch up front but the fuse is too pretty to cut. I found some 36" 2s balance plug extensions on Amazon so my plan is to put all of the charging points just inside the door.
Thanks again Josh.......Mark.
