Old 10-20-2019, 01:46 PM
  #357
VincentJ
VincentJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by speedracerntrixie View Post
What determines the 45 degree bend? Seems to me that you have a fair amount of movement of the surface with little rotation of the servo. If the bend were around 25 degrees it would require more servo movement to determine the desired throw and you would gain some resolution. Just thinking out loud here.
Speed, the angle of the wiper determines the approximate maximum deflection. See list below:
AILERON WIPER BEND ANGLE......20 30 35 40 45
APPROXIMATE MAX DEFLECTION 20 24 27 30 33
Your point is well taken, I'll have to check the rotation of the servo and maybe reduce the angle to 40 degrees. Thanks!
VincentJ is offline
