[QUOTE=BMatthews;12557921]Here ya go....
Thanks for that but I do have the 26-inch plan which is not the same build as the 32-inch. For my need the 26- inch is a standard build (if you look at the pik in this post servos in wing big mane spar Hi I think I have it sorted.the 40" wing is nothing like the 26".
But at 26 " it is good for a 020td I make it 81sq inch. Which is just a bit bigger than a tiny bit But it is good for a 020 td
Tiny Bit see outerzone
geoff
