Old 10-21-2019, 03:07 PM
Custmachr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by BarracudaHockey View Post
If everything is connected properly and you see the change on the monitor when working the trim, I don't see why the ECU won't pick it up.
Weird
The P60SE 6.0 ECU has the ability to use one throttle input or an additional channel with 3 position input switch for emergency shutdown, run and a programmed shutdown. If trying to use just one input you probably need the reset the ECU to just one input.
Hope this helps.
Custmachr is offline
